View Poll Results: Cam, nitrous or suspension?
Cam
11
28.21%
Nitrous
19
48.72%
Suspension
9
23.08%
Voters: 39. You may not vote on this poll
Cam or Nitrous next???
Im deciding on what i want to do for next year... whether i want to go for a cam swap or nitrous. The car is full bolt ons with a performabuilt lvl2 trans and a moser 12 bolt. The car has the original 73,000 mile ls1 in it and plans for the future when the original ls1 goes is an iron block 408. The car is mainly an 1/8th mile car only... so anyways my question is whether i should go for a cam swap or nitrous and i had one other thought and that was suspension work. What do you guys think?
go with the cam. my car is very similar and i went the nitrous path. not happy with results. i'm going with AFR 205 heads, G5X3 cam, and FAST intake/TB. I may keep the nitrous for a boost 3k - 5k rpm.
nitrous...you can't beat the hp and torque you get. Save the cam for the other motor and add the nitrous to it also. Spray the snot out of it and add the control arms and TA to it ...it will need it for both motors.
nitrous for sure... what cam out there can produce 150hp like nitrous can? and it only hits when you want it to. the car will drive stock until u hit the go go juice button
I vote Nitrous. You can't beat the bang for the buck.
A cam will produce some good results, but no sense in pulling the engine apart if you're planning a new build in the near future. Buy a good kit and save the rest of your money up for the new build.
I voted for the cam because you'll have that additional hp all the time. If you're going to put that 408 in soon then I'd go w/ the suspension then N2O. Remember...spinnin' ain't winnin'. haha!
