lets see your 4" dp on driverside pics
as title states, lets see your 4" downpipes on the driverside. Working on my DIY turbo setup and keeping AC so only choice is to run the 4" dp on driverside.
state which K member youre using, which motor mounts and if you had to do any extra clearancing
I have a OFI Turbo Kit, with a 4 inch dp. Are you doing manifolds or header style setup? I think you will have a harder time getting a 4 in pipe in there around with manifolds. If you search under my screeen name you will find pictures of my car. When you run the 4 inch exhaust out the drivers side, it gets kind of close to the floor by the factory subframe.
wont be using manifolds, they will be custom logs
