aluminum or iron block
next year I want to build a new engine and probably put it in my iroc. I have a f1 procharger on my current gen 1 sbc with 15psi, if I transfer this unit to a gen 3 engine, would an aluminum block suffice, or should I stick with a iron block?
i plan to stay on my current pulley and maintain around the same 15psi..
my current 383 has a 236/248 duration cam on a 113. i think i wanna take a step down on a cam on a gen 3 engine. like a 230/236 or something similiar.
this might increase psi a little.
Fireball just pushed a stock aluminum block to 1700rwhp before the stock lining cracked. So I would say that you should be alright aluminum. Just make sure you have a good tuner.
As stated above guys have taken the aluminum blocks really far. In my mind though, if you can afford the added weight, I like the idea of an iron block.
In the end, they both will probably get the job done...
Sounds like a 4"bore aluminum block should work just fine then.
lighter is better!
on a side note, I was thinking gen 3 block with l92 heads. edelbrocks 28455 manifold
stroker crank (4" stroke) . I already have an intake elbow and 90mm Throttle body.
then I just need ecm/wire harness. and procharger bracket and ls1 bracketry.(is that a word?) oh and sbc>ls1 mounts.
lighter is better!
for 15 psi id go aluminum and save weight but if you plan on upping the boost ever go with iron to be on safe side im planning on boosting a 366-370 aluminum with 10-16psi so it all depends on if you want the extra weight or not and yes the tune goes for iron and aluminum find a good tuner and your fine either way
8 sec potential, 12 sec slip
Well FIRST of all, your procharger won't work on a gen3 engine because the LS engines use a reverse rotation unit. Secondly, I'd go iron. Everyone says aluminum can last a long time, but I had bad luck with mine with my F1 and 15psi. Not that that had anything to do with how mine cracked cuz it probably would have cracked under a regular N/A application judging on where it cracked
Whatcha doing with the car?
Drag racing for fun?
Drag racing for competition?
Roll racing?
Just a badass street car?
Road racing?
Unless you're doing competitive racing and every .10 of a second counts.....go with the iron block. It'll be the last block you ever buy. The ~114 is meaningless for a street car or a street/strip weekend warrior. Whats the general rule of thumb....100 pounds extra weight is about .10 second in the quarter mile??? You can make up for that little bit of weight 10-fold by the amount of power you can throw at it and it'll laugh at 25psi. Why have an aluminum block that is WAY WAY weaker than an iron block. Makes no sense unless you're competing or if you just want 600-700 hp.
good point. lq9's are cheaper.
I do want to stay with a 4"+ bore block, so no ls1/6 for me as cablebandit said. 800hp is a sound goal ive had. right now my sbc 383 with my f1 is stupid fast, its only at 7psi now, I still need to swap pulleys. my current bracket looks like the one I posted above and it all clears my hood with about an inch to spare.
LS6427, I am drag racing for fun / serious street car. I run 17" zr1s with 315 in back for nice tread contact. I really never wanna go over a pump gas psi. I do have a meth kit in the works for maintaining detonation. no intercooler on my current 7psi setup, and if meth will support my 13-15psi goal, then I will probably avoid a intercooler and the messy piping that it comes with. but lets save that discussion for later..
I think I will go research 317 heads.. I understand thats a stock lq9/lq4 head?
I dont mind using a big port stock head, and in my mind that 800hp goal can be done with on plenty of stock head options. as long as they can hold the pressure, I dont see why not, my sbc does, but it also has many more head bolts
..and for fun.. my current setup..
Also, I think you can get a lightweight front sway bar to make that weight increase around 80 pounds net, IIRC.
