Rear suspensio for 87Fbody drag car??????
87 camaro. What can I use in the rear that wont cost a small fortune. Use a drag shock and keep stock coil spring? Or use coil over's... What are you guy's using with sucess. If I do go the coil over route, do I absolutly need double adj. I'm going to use a MT 275/60/15 drag radial. Spohn Rod end LCA. Spohn Extreme duty TQ arm. Spohn Panhard bar. Spohn Rear drag sway bar. I just have no idea what shocks to use. Auto trans.. Footbrake... 650 +/- Hp.
