Tube kmember and paying for allignments. Any one have any problems?
Old 10-06-2009, 08:55 AM
CamaroRick's Avatar
Default Tube kmember and paying for allignments. Any one have any problems?
I used to work at a chevrolet dealership, before we closed i used to do allignments on my own vehicles after hours, and now ive come to a point where i need to do an allignment on the camaro. The only issue i think im going to run into is that my UMI tube kmember does not have the factory holes in it which are used my the kent more push / pull tool. I have a feeling that wherever i take it they will complain and not get it to spec. Has anyone run into this in the past?
Old 10-06-2009, 10:20 AM
UMI Performance's Avatar
Hello,
Yes that is a small issue and some alignment shops get confused. We use a pry bar and push on the center tube of the A-Arm. If they know what they are doing they will figure something out
Hope that helps!
Ryan
Old 10-06-2009, 10:52 AM
EDS01SS's Avatar
When I had mine done I just researched alot of the local shops for people that were confident with working with a tubular setup. When I was satisfied with what they were telling me then I let them work on my car.Just gotta do your homework.
Old 10-06-2009, 12:47 PM
CamaroRick's Avatar
im pretty sure im the only one in a 50mile radius with a tube kmember. ill give a shop a try after i get new tires
The UMI is a nice piece btw
Old 10-06-2009, 02:25 PM
spy2520's Avatar
using a prybar sucks *****, but you gotta do what you gotta do i guess...
