Are these Valvesprings any Good?
Old 10-06-2009, 11:32 AM
VerdeZ28's Avatar
Default Are these Valvesprings any Good?
So ive been asking around cause i want to use a TR224 cam. People told me not to use the ls6 springs that i have and to instead use the comp 918. Well i was looking around on ebay and found some Elgin performance prostock springs that are rated at .600 lift max, which is a little less than the comp 918 but should be good enough for the .563 lift of the TR224. what do you guys think?
heres the link: http://cgi.ebay.com/ebaymotors/PRO-S...Q5fCarQ5fParts
Old 10-06-2009, 11:36 AM
baalic's Avatar
I may be wrong here, but I thought LS6 springs were stock for the 01/02 model Fbodys...... Springs and Intake...... soo, if LS6 spring were stock, I wouldn't see why an "OEM" spring would really be bad, but if your going to upgrade the cam, might as well upgrade the springs.
Old 10-06-2009, 11:38 AM
streetassasin's Avatar
Ive never heard of those, I'd just get som PAC 1218's
Old 10-06-2009, 12:31 PM
red04ls1gto's Avatar
Nope.....ls6 springs were used on ls6 motors, and 05 up ls2's And there are 2 different rated ls6 springs...
Old 10-06-2009, 12:59 PM
VerdeZ28's Avatar
i have the better yellow ones....
Old 10-06-2009, 02:35 PM
TooLateVTEC's Avatar
Elgin stuff has been around for years.
As long as the spring pressures are where they need to be for that camshaft than they arent bad.
Would I personally use them? Probably not, unless I was on a really tight budget. I would rather use some PSI or PAC springs myself.
My 2 cents.
Old 10-06-2009, 02:39 PM
LS1-450's Avatar
The .600" lift relates to coil bind dimensioning only & does not address valve float. Upgrading springs usually relates to eliminating valve float first, along w/ having no coil bind. The springs you linked are 130# seat & 318# open, similar to 918's. So, as long as your lift isn't greater than 0.563" w/ the average duration @ .050" being what TR224's are (don't recall, but remember it being OK), then either the e-bay or the 918's are OK. If you are using a greater than 1.7:1 (stock) rocker arm ratio, then you will need a stronger valve spring (your lift would be .596" w/ a 1.8 rocker; for example).
Old 10-06-2009, 02:56 PM
KCS
Moderator
KCS's Avatar
I'd stay away from ebay valvesprings. That's one part that is too highly stressed to cut corners on. I would just go with the 918's, set them up correctly, and enjoy.
Quick Reply: Are these Valvesprings any Good?
