Best bolt on head with stock cam?
Old 10-06-2009, 05:56 PM
Stringfellow's Avatar
Default Best bolt on head with stock cam?
Im considering swapping heads after reading a few articles in GM High tech with dyno proven results.
I dont want to go into cam swaps , but heads seem to be as far as I'd go.
What would the experts say would be the best bolt on ( no port work or polish) to work best with the stock cam or perhaps bigger rockers, BUT it has to be still be daily driven with a good torque increase in the stock rev range as I wont up the rev limiter as I'd never use that kind of rpm.
I plan on full length headers to compliment this and leaving the stock LS6 intake and TB/MAF, yes, it has an SLP lid and filter.
Curious as to what power can be obtained this way, thanks.
Old 10-06-2009, 06:00 PM
JonCR96Z's Avatar
You'll have to spend some money to get a set of heads that will give you any noticable gain on the stock cam. And even then you might get 15-20hp?
A cam swap is much easier and and cheaper and can gain you any where from 10-60rwhp depending on how big you want to go. 'Daily driven' is very subjective.
Old 10-06-2009, 06:10 PM
LS1crazy01's Avatar
I saw a thread a while back where someone made just over 400 rwhp with just heads. Talk about a sleeper!
Old 10-06-2009, 06:14 PM
JonCR96Z's Avatar
What the **** ever.
Old 10-06-2009, 06:18 PM
jman54002's Avatar
yea I would like to know the answer to this also?
Old 10-06-2009, 06:23 PM
NemeSS's Avatar
yup, i think it was patg with set of afr's and stock manifolds iirc
Old 10-06-2009, 06:30 PM
JonCR96Z's Avatar
Manifolds too? The only way I would believe it would be if it were someone like Pat G who left nothing untouched and everything was perfect. I mean aren't there full bolt on cars making 370-380? I guess a $2500 set of heads (possibly even worked on) would put that over the mark.
Still, a complete waste of time and money if that's all you're going for.
Old 10-06-2009, 06:47 PM
LS1crazy01's Avatar
Originally Posted by JonCR96Z
What the **** ever.
OK...........................
And yeah it was that Pat G. thread. When I read it I got to thinking as well.
Old 10-08-2009, 01:31 PM
I just read in the newest GM Hgh tech on project CT (99 SS with CARB leagal mods) anf they installed AFR heads (205's i think) and the closest to CARB leagal cam being the 02-04 LS6 cam and they got about 20hp and I find no reason for that much work and money for little gains like that.
What Im really talking about is the article where they took a stock 01 WS6 and added Edelbrock/lingenfelter heads (about 2400 bucks assembled and CNC'd) and made just under 54hp at the wheels.
Anyone else do this or something close? I would also assume gaining a few more ponies by adding FL headers/exhaust and a tune. That would be about as far as I'd consider going with my car.
Old 10-08-2009, 02:09 PM
massls1guy's Avatar
Sounds like you're avoiding the cam swap because you like the mild manners of the stock cam.
Fyi, you can go with a 224 cam (e.g. TR224 114lsa or TSP 224R 114lsa) and have very good street manners. With a 224 cam, 241 heads, all the regular bolt on's and a tune you will be somewhere around 375rwhp.
I've driven my Z28 about 100k miles over the last 4 years, with about 155k miles total on it now. I installed my 224 cam and 243 heads 2 years ago at about 110k miles.
It does fine in bumper to bumper traffic, running the AC on a hot 95 degree summer day. If there is no snow or ice on the ground I drive it in the winter too. You really don't give up any street manners at all with a small cam.
Old 10-08-2009, 02:12 PM
GreenbeanZ28's Avatar
What the **** ever.
I have dyno charts for every single mod the car has ever had, just in case you need further proof.
https://ls1tech.com/forums/dynamomet...stock-cam.html
Old 10-08-2009, 02:23 PM
twitchtwice's Avatar
very impressive. it would be nice to have that kind of power with the stock cam. and those were just reworked 241s?
Old 10-08-2009, 03:59 PM
Golf&GM's Avatar
GreenbeanZ28, did you ever get to the track on that setup?
Old 10-08-2009, 04:42 PM
alamantia's Avatar
I think all heads bolt on
Old 10-08-2009, 05:09 PM
transwiz's Avatar
If you are on a budget you could get a used set of 243's heads with low miles on the classified section of this forum.I would also do a cam if I were you.There are all sorts of mild cams you can get as mentioned earler.A tr224 is a good all around proven cam.Or maybe something around 218 to 220 is still a small cam but very streetable.It's all in the tune you get as to how streetable it will be.If it was me I wouldn't do just the heads.If you like the stock manners a lingenfelter gt2-3 would be also cool.
Old 10-08-2009, 05:23 PM
Yea, just CNC'd and milled
No I havent, but I recently did get an LS6 cam in there, but it got some issues....lifters maybe, its got some racket going. Did manage to pick it up to 449 rwhp, may get 5-6 more out of it when its all said and done.
Old 10-08-2009, 08:06 PM
OSU Football Fan's Avatar
Well I'm no expert & I don't really know what your budget is.
But if it was me, I would go with Texas Speed ported LS6 or 5.3 heads.
They seem to be the best aftermarket ported head for the price.
I would also get a set of 1.85 rockers & a good dyno tune.
As long as you keep the stock cam you should have really good torque
& it should be very driveable.
If you were wanting to go cheaper, you could just find a set of used
243 heads. I don't think that I would go to the time, trouble, & cost
to swap used unported heads though.
Old 10-08-2009, 09:17 PM
10 Second Fun Car
jlrz28's Avatar
TEA 5.3 heads or the 5.7 heads. I was very impressed with the numbers I gained.
