Build Thread: Headed for the stock cid LS1 nitrous record
Old 10-06-2009, 06:15 PM
02SS:ZEUS's Avatar
Default Build Thread: Headed for the stock cid LS1 nitrous record
Just figured I'd start a build thread. The car is a 2002 SS Camaro. The best it's been so far is a 10.34 @ 130 on a 150 shot. That was with stock heads and stock guts...other than the cam.
Here is some info on the new set-up....
Motor:
-346 cid LS1
-Callies Crank
-Callies rods
-Weisco nitrous pistons
-AFR 205's
-EFI Victor Jr.
-Wilson Pro Flow Direct Port nitrous
-Wilson 4150 throttle body
Transmission:
-Rossler RMVB TH400
-ATI converter
Rear-end:
-Moser 12-bolt (Narrowed 5")
-35 spline axles
-Spool
-5/8 wheel studs
Suspension:
-UMI....if they make it, it's on the car
-AFCO rear shocks
-QA1's up front
-Aerospace rear drag brakes
-Strange front drag brakes
That's pretty much the jist of it. The car is getting gutted and re-wired. Everything under the hood the car doesn't need is gone...and when it goes, the car will be heading off to get re-painted. It's getting a sheet metal gauge cluster with all Autometer Cobalt full sweep gauges...8 of them. The record for a stock cid nitrous LS1 is 9.3x as of right now, so that's what we're shooting for, then we'll slow it down a little and do some index racing. The car is being built/put together by R.P.M. in Garner, NC. I'll post pics up as I get them...then hopefully some 9.2x numbers by March. Here are a couple pics of the car before the stock motor came out.
Old 10-06-2009, 06:44 PM
CamaroRacing12's Avatar
thats a crazy record! very impressive! good luck!
Old 10-06-2009, 08:48 PM
jmill96Z's Avatar
Sounds like you have a pretty good plan. Best of luck to ya.
Old 10-06-2009, 10:35 PM
Magnet's Avatar
Wow, car looks sick bro! Build sounds awesome too!
Old 10-06-2009, 10:39 PM
SMITH's Avatar
i think i have had the record for a few years now, its time for somebody else to get it. good luck.
Old 10-06-2009, 11:46 PM
camscam02's Avatar
love the wheels.
good luck with the build, I would be right there with you if I could afford to build a motor, instead im gonna see what I can push this stock bottom end too. hoping 9.50's or so.
Old 10-07-2009, 05:37 AM
02SS:ZEUS's Avatar
I just figured with you running 5.0x's now you could afford to give this guy up. lol I'll keep it in NC though.
Old 10-07-2009, 06:52 AM
Fireball's Avatar
Probably best suited in the Nitrous section...
Old 10-07-2009, 11:10 AM
8 second mod
Noyzee's Avatar
big mike had it for a while, i took it from him for a while, now you have had it for a while. time to give up your crown. lol
go solid roller and the other suporting parts you have listed set up correct i dont see the record being an issue.
if i knew then what i know now as im sure smith will tell you the same, im sure we would have been faster for sure. the new parts and tuning available and tuning knolage etc should make the record prety easy to grab.
good luck. sharp car
Old 10-07-2009, 04:55 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Good luck. There's a couple other guys gunning for it too that are quite a bit ahead of you.
Old 10-07-2009, 05:15 PM
MelScrilla's Avatar
with that setup and about 300-350 shot of the juice you should be all over that 9.2 good luck
Old 10-07-2009, 05:22 PM
jmill96Z's Avatar
That's the plan for my junk. Along with freshening up the short block.
Old 10-07-2009, 10:47 PM
NVR_SPDS's Avatar
Good luck Ken, i hope you see 9.2s or faster!
Old 10-07-2009, 11:00 PM
Y2K_Camaro's Avatar
Great looking car and sounds like a solid plan for the build. Best of luck and keep us updated
Old 10-08-2009, 12:16 AM
slowredz's Avatar
What was the 1/8 mile time on the "record pass"
Old 10-08-2009, 12:29 AM
Sofls1's Avatar
Love the wheels, what are those? Also love the fact you still have a/c on this car!
Old 10-08-2009, 12:37 PM
8 second mod
Noyzee's Avatar
let me know if you need a hand picking a cam, or setting up the heads for solid roller.
Old 10-08-2009, 01:07 PM
UMI Performance's Avatar
Get us some pictures when she is done
Ryan
Old 10-08-2009, 01:25 PM
Nitro Dave's Nitrous Outlet's Avatar
Sounds like a nice build.. Good luck..
Dave
Old 10-08-2009, 03:07 PM
02SS:ZEUS's Avatar
Thanks for all the feedback guys. I'm keeping the car a hyd. roller....gonna let RPM work a little magic with it. It will be a high compression motor as well. The car will weigh right about 3k pounds with me in it.
BTW, the a/c is now out of the car. lol
Ryan
I'll get with you this week Ryan. Gonna have you send a few things over to RPM for me. I'm in Afghanistan, but I should be able to give you a call instead of my woman for my morale call. LOL
Quick Reply: Build Thread: Headed for the stock cid LS1 nitrous record
