Need a raw .bin
Old 10-06-2009, 09:02 PM
turbogtu's Avatar
Default Need a raw .bin
Tried a search and had no luck. I blanked out 4 PCMs. I got a programmer to bring them back from the dead but I don't have a .bin to load onto the chips. Can somebody help me out. I use EFI Live, so the files I have are encrypted. I need a raw bin.
Also If anyone knows were/how I need to put the ID in there so that I can use the licenses that I burnt on these that would be great.
Old 10-06-2009, 09:14 PM
CalEditor's Avatar
I need more info.
What OSID and PCM #'s?
Yes I have read out Bin files for most of everything.
Old 10-07-2009, 04:37 PM
turbogtu's Avatar
just about any osid should work but no etc. Reason I need it is mainly for the boot portion of the chip, the calibrations don't matter because once I get the pcm booting up again, I'll recalibrate it with EFI LIVE. Maybe throw a couple my way so I can fumble through.
pcm is 12200411
Thanks
Old 10-07-2009, 04:49 PM
Billiumss's Avatar
Arrow
Here ya go.
This is from a 2002 Trans Am A4.
Download the file and change the .hpt to .bin
LS1tech does not accept .bin files for upload
Bill
File Type: hpt
Old 10-07-2009, 05:12 PM
turbogtu's Avatar
any advise on the reprogramming? I'm using a willem and so far no luck. Chip is programmed fine and verifies ok but the pcm still is dead.
For example, do I need to set an offset or invert the data?
Old 10-08-2009, 03:23 PM
turbogtu's Avatar
Am I on the right track reprogramming the 28F400 flash chip to bring my pcms back or should I be looking somewhere else?
Quick Reply: Need a raw .bin
