Used cam has a flat spot.. check it out.
Old 10-06-2009, 11:38 PM
LargeOrangeFont's Avatar
Default Used cam has a flat spot.. check it out.
I got this cam used from another member. He said the cam was in good condition, and when I got it I found a flat spot on one of the lobes. The transition on and off the flat spot is very smooth, and there are no scratches that can be felt with a fingernail in this area.
I think this might be junk. What do you think?
Old 10-06-2009, 11:45 PM
mvvette97's Avatar
Junk for sure. That cam is worth nothing at all. get your money back
Old 10-06-2009, 11:46 PM
cutlass_455's Avatar
First thing I gotta say is, nice eye man, good find.
Second thing is, that sucks major ***.
Third thing is, I wonder what would cause that to happen....maybe there was a piston that hit a valve and it transfered all that stress down and pushed the lifter into the lobe.
Fourth thing is, that sucks you the shaft (no pun intended) from a fellow member.
I dont think youd wanna use that cam. I dont think I would.
Old 10-07-2009, 12:09 AM
Well at this point I don't think he screwed me. I'm hoping it was an honest mistake and that we can work it out. He has a 100% positive rating on this site.
I sent him a PM tonight.
Old 10-07-2009, 07:58 AM
Jim85IROC's Avatar
Just put a little bondo there.
Old 10-07-2009, 08:08 AM
deelong4002's Avatar
good thing you caught that.
Old 10-07-2009, 09:05 AM
cabolew's Avatar
Good pictures. I would have never thought to look that closely.
Old 10-07-2009, 10:06 AM
TooLateVTEC's Avatar
Junk.
Its now an expensive paper weight or a weapon.
Old 10-07-2009, 12:09 PM
1INSANEGTO's Avatar
Originally Posted by TooLateVTEC
Junk.
some people carry shovel handles in there car now you carry a cam for protection
Old 10-07-2009, 12:22 PM
3.8redbird's Avatar
custom grind cams are what 350-400 right? why risk the defect buy new
Old 10-07-2009, 12:46 PM
Seller responded and is willing to work something out. Mistakes happen and he did not see this damaged area.
I got this for 50 percent of the new price, so I thought I would try it. I'm thinking I should just spring for new cam, or at least a used one locally that I can inspect before I purchase.
Old 10-09-2009, 09:11 AM
Horsepwraddict's Avatar
Could have happened during shipping, dropping it (or dropping something on it) could have done that too.
Quick Reply: Used cam has a flat spot.. check it out.
