NEED torsen diff parts!
Im in need of parts for the torsen style differental used in 98 up f bodys.What do you guys have? im looking for some parts that go inside the carrier.
try the dealerships..........they usually can get you the gears and such for them..i dont know of any aftermarket companies ......i'm sure someone else will chime in and say buy truetrac or something..........i have a carrier but i am gonna put it in my xtreme
Is there a guide on rebuilding the torsen? My rear has been making a lot of metal on metal groans lately. I took off the cover and from what I could see nothing looked bad or worn. Hard to see inside the carrier though. Which parts are you looking to replace?
I need the part that goes between the axle shaft ends inside the carrier its held in with a bolt. The part truthfully looks like a paddle.I checked with the dealer no parts available.
Maybe post in your local/regional room that you need the paddle. I think a lot of people end up with stock 10 bolts laying around when they upgrade, maybe you can get it for free.
Did something happen to your original paddle - did it wear, break, crack etc. How did you know you needed a new one.
