Found a 6.0, does it have vvt? I have the vin #
Found a 2007 6.0 LQ4 for pretty cheap. Need to know if it has vvt. Its 200 miles from me so i can't check. The vin# is 1GTHK23U47F196913. Can anyone tell me from this vin if it has vvt? Thanks fellas.
better ls2 full floating rods and rod bolts. its fairly easy to remove and disable vvt. so that wont be problem, but if its a lq4, u will have no such problems.
if u buy motor, make sure theyleave flexplate and spacer on there.
that way u will be able to use a th350/400 or 700r4.
