Questions on new 2 Bar MAP??? With pics...
Old 10-07-2009, 05:01 PM
vipvegas's Avatar
Default Questions on new 2 Bar MAP??? With pics...
Correct me if Im wrong the first picture is of my stock MAP out of 01 WS6 on the right.. On the left is the new 2 bar. Here is the question
The 2bar has a different connector. There both 3 prong but different style.
The connection for the 2 bar is facing down in the intake as the stocks connector faces to the right..
Can anyone enlighten me whether I got the wrong part?? Or what to do with this thing..
Thanks
Old 10-07-2009, 05:34 PM
vipvegas's Avatar
Guess Ill answer this myself. Ill tap the rear of intake with a 1/2 and put a barb, then run vaccum line to MAP. I got the 3 plug GM Weatherpack connecter from NAPA 4 bux total in parts. Ill splice in and will be done.. believe this is the pinout
MAP Sensor Pinout...
They all share a common pin-out, although the connector keying may be different:
Pin A -- Ground
Pin B -- Sensor output
Pin C -- +5 volts
Old 10-07-2009, 06:03 PM
Matt97Ta's Avatar
thats an lt1/tpi style sensor
Old 10-07-2009, 06:09 PM
vipvegas's Avatar
Will it work if I do the above..
Old 10-07-2009, 06:39 PM
KILLER-LS1's Avatar
the direct fit one is from a supercharged colbalt. just go buy the right one. it has the same connector
Old 10-07-2009, 06:51 PM
WS6HUMMER's Avatar
Yeah they make adapter harnesses for that style to work, you can also T one of the lines off the front of the intake right by the TB if you dont want to drill a hole in your intake.
Old 10-08-2009, 03:54 AM
BLOWNBLUEZ06's Avatar
If you don't want to go through any modifications, use the BARO sensor from the Cobalt. Part# GM12580698 or replacement for that #. I think I paid around 40.00 for it. Same plug. Same pin out. Same form factor as the stock MAP. It's what I've been using on my car since I converted it to a 2-bar. It works great.
Quick Reply: Questions on new 2 Bar MAP??? With pics...
