Is there a such thing a bottle too full?
Old 10-08-2009, 08:25 PM
blubyu02's Avatar
Default Is there a such thing a bottle too full?
I got my bottle filled 2day and it is now 8pm and my guage still reads 1500psi the bottle isnt anywhere near hot or warm. 2day after i put it back in my car it stayed pegged out past 1500 should i take it out?
Old 10-08-2009, 08:34 PM
Ph.D. in HUBRIS
custm2500's Avatar
Yes a bottle can be too full. It has a pressure release so it won't explode but it could spray nitrous in your car. I would take it out till you are ready to run then re-install it. Make sure to keep it in a cool place. With pressures so high you might want to blead some off because you may lean out on your first run or two because you will be running so much extra nitrous. Others will have to chime if this is much of an issue but I know it is possible.
Old 10-08-2009, 08:50 PM
1BADAIR's Avatar
i have had them too full. When it was cold out it didn't take really any heat to get to pressure and then the pressure dropped a ton as soon as the kit came on
Old 10-08-2009, 09:17 PM
BAKED's Avatar
Weigh it and if it is over what the label says it should be when full then let some out till it weighs the right amount. If you try to spray your motor with 1500psi it is going to go WAY lean till the pressure drops back down to 900-950psi.
Old 10-08-2009, 09:26 PM
Ph.D. in HUBRIS
custm2500's Avatar
I thought this was the case but didn't know how it worked in the real world.
Old 10-08-2009, 09:38 PM
6 & 8 Second Club
mrdragster1970's Avatar
Burp a little to make sure it's not the gauge??
As mentioned, if overfilled, it won't work as it was designed for pressure & temperature.
Old 10-09-2009, 12:09 AM
blubyu02's Avatar
K thanks tech im going 2 take it out and blow sum out my purge quit on me or else i would give sum kids a show.
Old 10-09-2009, 09:46 AM
Nick@HSW's Avatar
Yea if your purge isn't working then chances are the pressure is way too high. You'll have to crack open the valve to relieve some pressure.
Nick
