Performabuilt transmission...What tuning needed on install?
Old 10-09-2009, 12:29 AM
camz28arro's Avatar
Default Performabuilt transmission...What tuning needed on install?
When I install my performabuilt level 2 transmission and yank ss3200, which tuning would I need to do so it will work fine or any codes that should be deleted. Shift points will be raised to 6200. I won't be doing the tuning but would like to know what to tell vettedoctors what I want. I heard that I shouldn't change any of the pressure tables or smoething. Thanks.
Also after installing the transmission, torque converter, ls6 heads and cometic gaskets, would it be ok to drive the 25 miles there or should I get it towed there on a friends flatbed, I'm also going to get my 3.23s and truetrac installed by them before the tuning.
Old 10-09-2009, 12:42 AM
Frost's Avatar
If you need to tell your tuner how to do his job, you may want to shop around. I would think that the Vette Drs are more than well enough versed to do what is needed; they won't/don't need to be told what to do.
Old 10-09-2009, 01:01 PM
camz28arro's Avatar
Thats what I was thinking but I can't be too safe with my car, do you think they know to shut off the PO751 and PO757 codes off though?
