signs of 10-bolt going bad
Old 10-09-2009, 02:11 PM
Asian LSX's Avatar
Default signs of 10-bolt going bad
Are there any signs the 10-bolt is going to break or does it just happen all of a sudden?
Old 10-09-2009, 04:48 PM
tko0383's Avatar
Normally the rear end will whine or roar. But launch a healthy 10bolt at 4K on a sticky tire and will usually just pop with out warning.
Old 10-09-2009, 06:26 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea, a whine or howl is a tell tail sign. Also one legged posi shots.
Old 10-09-2009, 07:42 PM
xRelapse13's Avatar
how bout a vibration?
Old 10-10-2009, 02:31 PM
BennyB's Avatar
I had a lot of vibration and a lot of howling just before mine went... you will know if daily driving... if at the track and hooking that thing will just POP!
Old 10-14-2009, 12:03 PM
Shamson5.7's Avatar
Mine sounded like an airplane turbine all the time when it was going out. Then it sounded like a machine gun shooting out grenades when it really did start to go...one loud bang and a rearview mirror later it was kaput.
Old 10-14-2009, 03:46 PM
Mean87SS's Avatar
Mine was fine... mid luanch the rear blew...
Old 10-15-2009, 01:48 AM
xXxSilveradoxXx's Avatar
Originally Posted by Asian LSX
Are there any signs the 10-bolt is going to break?
Yeah, right here.
Old 10-15-2009, 02:17 AM
35th SS's Avatar
keep doing that on your sig. and your on borrowed time.
Old 10-15-2009, 05:03 AM
BAMF's Avatar
I found the trick to keeping 10 bolt rearends in a 4th gen.......buy a few 10 bolt rearends so when one breaks you have a spare LOL
Old 10-15-2009, 05:17 AM
Asian LSX's Avatar
I was was waiting for someone to comment on that. lol
I'm more interested in people hearing or experiencing something in normal driving.
Old 10-15-2009, 06:05 AM
cambirdracing's Avatar
Are there any signs the 10-bolt is going to break ?
http://www.youtube.com/watch?v=ivKuL3AMVv0
Old 10-15-2009, 06:18 AM
DutchmanZ's Avatar
Signs Signs everywhere a Sign. When I read the title my answer was simple. If it is moving, it's going bad. Most often they leak at the pinion seal and someone over tightens the nut after replacing the seal. This is followed by gear noise and then 'poof'.
Old 10-15-2009, 08:03 AM
35thLE02's Avatar
It's best to just plan for it to break. My 10 bolt has no problems of any kind. The rear is quiet. But i'm ordering a 9" in the next few months. I don't want to be the guy at the track getting towed away.
Old 10-15-2009, 09:06 AM
wrd1972's Avatar
Yeah.
KABOOM. HOLY ****!!! WTF WAS THAT???.
Old 10-15-2009, 09:07 AM
BoneStockWS6's Avatar
I've been replacing wheel bearings in our WS6. Next is the leaky pinion seal. Any advice on how NOT to overtighten it?
Old 10-15-2009, 09:16 AM
Asian LSX's Avatar
Originally Posted by wrd1972
Yeah.
Thanks for stating the obvious.
Old 10-15-2009, 09:52 AM
wrd1972's Avatar
Actually I was being serious.
Whining or noisy gears are not really an indicator, IMHO, that the 10 bolt is going to break. That just means that the gears are worn and require replacement. Same thing with wheel bearings or any other bearing.
If the rearend where making a bad clunking noise as a result of a broken tooth, this would be an indicator. But this is rarely the case.
There are no signs the 10 bolt is going to "break". It happens all of a sudden basically the way I stated it for the most part. Kaboom.
Old 10-15-2009, 10:21 AM
Asian LSX's Avatar
Thanks for the input. Doing some searches I never really found anybody say anything happened leading upto the rear end breaking. Just thought I'd ask though and post the topic.
Even though my sig pic shows me trying to break the rear, I only did it once to get a good pic. 10 years, 85k, knock on wood.
Old 10-15-2009, 10:54 AM
bracketracerZ28's Avatar
I have been racing on mine for 3 1/2 years. It has busted 3 times, all at the track. I usually hear the teeth sheering a couple of runs before it blows. My problem has alway been when the ring and pinion go, it takes out the low sprag in the tranny....then it gets expensive
Quick Reply: signs of 10-bolt going bad
