How to coat the under body of my red Camaro?
I want to use something like POR-15 but I kind of want to keep the red look on the underbody. I don't want the black look.
The factory coating has some rust spots (I can probaly scrape the rust off with my fingernail) but I feel it's better to coat the underbody now rather than worry about deep rust spots later on.
What are my options. I wish there was red POR-15
Copy & Paste Moderator
Check out their website:
http://www.por15.com
Here is the rust preventative stuff specifically:
http://www.por15.com/product.asp?productid=6
It looks like the only available colors are:
Black
Clear
Gray
Semi-Gloss Black
Silver
--VIP1
Black
Clear
Gray
Semi-Gloss Black
Silver
--VIP1
Moderator
POR-15 is good, tough stuff. Consider using it as a base
(maybe gray or black) and then color-coating it. Check
about surface prep & compatibility w/ your preferred
color coat paint formula.
But POR-15 is really meant for bare metal and if you
haven't damaged the factory under-paint then maybe
what you want is a good epoxy paint instead.
Check this out for more info on dealing with the stuff:
http://www.por15.com/uploads/files/p...on%20sheet.pdf
http://www.por15.com/uploads/files/p...fo%20sheet.pdf
--VIP1
--VIP1
