My tire got screwed..
Old 10-10-2009, 01:23 AM
98 WS6's Avatar
Default My tire got screwed..
Pulled into the driveway after some cruising, and a screw fell out of my front tire. I plugged it with one of those rubber strip plug kits. I'm guessing i'm going to need new front tires now? They're 275/40/17 ..
Can anyone recommend me some good, cheap performance tires? Unless I can still run on these.. (which I doubt)
Thank you
Old 10-10-2009, 05:46 AM
hitmanws6's Avatar
Thank you
BFG Super Sport, Falken 452, Nitto 555
Old 10-10-2009, 09:44 AM
streetassasin's Avatar
I have nexen n3000's on the front, you can find em online for around $90 ea for a 275/40/17 or around $80 for a 255/40/17, Im running the 255's
Old 10-10-2009, 10:51 AM
Saturn5's Avatar
If the screw was in the tread of the tire, there's no reason the plug won't hold for the life of the tire.
Old 10-10-2009, 11:33 AM
DriftR's Avatar
Yeah, if the screw is in the treads and not in the sidewall you can plug it. I would recommend having the tire removed and adding a vulcanized patch on the inside as well though. I'll add Kumho Ecsta SPT as another cheap but very impressive tire for the money. Decent grip dry and excellent wet.
Old 10-10-2009, 02:06 PM
98 WS6's Avatar
Thanks guys. Yep, the hole was in the tread. DEAD in the middle of the tread. We used one of those rubber plug kits from (lol) walmart. What you do is take a long piece of rubber, cover it with "rubber cement," then use a tool to shove it in, completely filling the hole. Then I can either, cut off the excess, burn it, or let the road wear it down.
So you guys think it'd be safe just to roll like this? I don't wanna be doing like 110 somewhere (ocean parkway ) and blow the tire.
Old 10-10-2009, 03:25 PM
1slo_camaro's Avatar
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
i hate three holes in one tire a front tire at that and it lasted me about 30 100 mile trips and i dont think my car ever saw under 90 or 100 except for going through toll booths. I-95. they should hold good if it was done right.
Old 10-10-2009, 03:35 PM
98 WS6's Avatar
I guess I'll get it plugged/patched correctly once I get my wheels mounted/balanced.
Old 10-11-2009, 01:43 PM
shaun's Avatar
i would just go to a good tire shop and have it pluged the right way it souldent cost more than 20
Old 10-11-2009, 04:18 PM
qwk93ta's Avatar
I've plugged many tires and have never had a problem.
Old 10-11-2009, 06:04 PM
leadfoot4's Avatar
In case you decide on new tires, The Fuzion ZRi is working pretty well for me...
Old 10-11-2009, 07:34 PM
colby72olds's Avatar
Yeah, you shouldn't have a problem.
I thought you was waiting on some tires for the Z06's though??
Old 10-11-2009, 11:18 PM
02TransAm/Batmobile's Avatar
I thought pluggin' tires were frowned upon and that patching is the way to go? Being that by pluggin', you are opening up the hole and patching seems to me you would be sealing it more effectively.
Old 10-12-2009, 01:13 PM
Saturn5's Avatar
Tire shops are going to do the exact same thing he did, except charge $20 for the same plug.
98 WS6, you said it was in the middle of the tread. If it's holding air and not leaking down, consider it fixed and don't worry about it. Many tire shops don't even do internal patches anymore because they're more likely to fail than a plug. I've plugged many tires over the years and if it was in a tread block, I've never had a problem for the life of the tire.
Now, if you routinely drive on the autobahn at triple digit speeds for hours on end, you may want to replace the tire. But if you drive in the U.S. and rarely see over 100, and when you do it's for only a few seconds or minutes at a time, don't worry about it.
Old 10-14-2009, 09:19 PM
98 WS6's Avatar
Sweet, thanks dude. That was the kind of answer I was hoping for. Amd you're right, I got the new wheels mounted today, and the shop only did plugs, no internal patches. Seems to be holding up fine, thank goodness.
Ironically, (whoever said this) the front tires ARE Fuzion ZR1's
