Fueling & Injection - Double pump diagram
View Full Version : Double pump diagram
KrisXpc
10-10-2009, 05:34 AM
Gently critic this please! Im still learning lol.. this is what ive come up with. I could be way way off...
All the sponcers are awesome! :D
But... I want to do this on my own. Just to do it and save A little coin.
http://img188.imageshack.us/img188/7442/fuelattempt.jpg
KrisXpc
10-10-2009, 05:38 AM
oh! forgot to mark the 20 amp fuse before the hobbs switch!
3fingas
10-10-2009, 09:03 AM
I would put the FPR on the end rail with the sensor and return it from there. Why the -8 feed? -6 would be fine unless you plan on boost. You can also use the stock feed as the return and only run one -6 line.
KrisXpc
10-10-2009, 02:48 PM
My car is running a F1 procharger setup. I get braided line for free. (I build Helecopter engines) So i might as well use it!
DopeFedZ
10-10-2009, 11:49 PM
You want your regulator after the fuel rails.
The link below should help.
http://www.kinsler.com/Cat_31_Web_HTMLs/0201234_screen71.html
koolaid_kid
10-11-2009, 08:27 AM
You really don't want that much current running through the Hobbs switch. Use it to power a relay, which then handles the power requirements of the second pump. This is a very standard method of running power to a high-current device, such as a fuel pump, EWP, etc.
You would also be well served to put a Racetronix harness on the first pump. It is the one that runs almost all the time, and the factory wiring is woefully inadequate of the power requirements of a 255lph pump. You can't build one to their quality for what they charge, so I suggest you purchase that one outright.
KrisXpc
10-11-2009, 04:29 PM
Good advice Will do!
