installing rear lowering springs question
I did a lot of searching but I didn’t find the answer I was looking for. I am going to be installing some rear lowering springs and I was checking out the LS1Howto.com install but they are replacing both springs AND shocks. Do I really need to get under the rear carpet and unbolt the top of the shocks? If I am only doing the springs so can I unbolt them from under the car? Thanks!
Support the car. Get a jack under the rearend. Unbolt both shocks at the bottom off of the rearend and lower the rear w/ the jack. Its easy.
