General Maintenance & Repairs - Running rough...again.
View Full Version : Running rough...again.
black2001ws6
10-11-2009, 05:58 PM
Alright heres what happens. I start the car. Its idle immediately drops and car dies, unless I give it some gas and slowly let the gas out until its sitting about idle range then it will sit there. After that when I drive it and I go to sit at a stop light or stop sign or take it out of gear period. The engine ALMOST dies unless I keep my foot on the accelerator giving it gas. Just had a new pcm put in like the dealer said and they said it should fix it. Well obviously it isn't fixed..ugh idk what to do!
LS6427
10-11-2009, 06:06 PM
IAC valve maybe. And no, you won't always get an SES light....you'll get the SES light and/or a code when it totally fails. Kind of like an idiot SES light/code.
black2001ws6
10-11-2009, 06:30 PM
Also, the car doesn't do it when its at operating temperatures, just when it's cold started.
wssix99
10-12-2009, 10:10 AM
What kind of transmission do you have? Do you have the same issue in neutral?
black2001ws6
10-12-2009, 05:55 PM
I figured out what it was. My battery had a bad connection, so when it was sitting there it would reset the pcm everytime I turned it off. Causing the new pcm to have to relearn everytime I started it. Running great now. Thanks!
