Compression Ratio Question (LQ4 + L92?)
What sort of compression ratio can I expect on a factory LQ4 with L92 heads?
It's a very general question with alot of factors, but I'm seeing if it's taking me in the wrong direction. I want to keep the low compression for boost.
Robert
Robert
I did a search and came up with 70cc chambers in the heads, vs. 72cc for 317 heads commonly found on 6.0L engines. So a very general answer is, yes, you may be going the wrong direction, but not by much. I plugged some numbers into the DCR calculator I use and came up with 9.46:1 for 317's and 9.66:1 for L92's.
If you are going to be adding much boost, it makes sense to step up to a forged piston anyway, at which point you have several options to get your compression exactly where you want.
