chevelle install ?
chevelle install ?
Please chime in those with experience installing an LS/tko combo into an A body(68 chevelle). Can the engine trans be installed together or must the trans be installed independently. Can at least the bell be installed on the motor? Im using the typical autokraft pan and edl mounts but was hoping to do as much preassembly as possible. Thanks
You should be able to install it either way.. eng/tran combo (it can be a tight fit) or engine 1st with bell housing and then bolt in the trans.
IMO ...it will cut time if you drop them in together..! but mock up the adapter / engine mount 1st without the trans...
on my 64 malibu i jacked the car (nose) up as high as my stands could go and i tiltd the engine and tranny as much as i could and sliped my 5.3/4l65e in and i used the milodon pan witch is pretty wide, so you shouldnt have a problem. good luck
