Electric Cut out
Hey mel,
When funds get a little higher, I'm springing for this one, and the electric controller: http://www.quicktimeperformance.com/OVAL/index.php
i have this one. its cheaper then off QTP's site.
http://www.pfyc.com/pc/GN5002/04EXH/...nd+models.html
they also have this one. i wish they had this available when i bought mine cuz i woulda went with this one.
http://www.pfyc.com/pc/GN5018/04EXH/...st+Cutout.html
i have mine where the res used to be....i know some have put it down the line a little further so it exits right by the rear wheel....it kinda depends on how much noise you want lol....mine is pretty loud since it is close to the DP with no bends...if you put it down further it wont be as loud.
i dont think the oval one would work if you are going to want it up that close unless you would have it in front of the cat right where the bend is from the DP to the cat (thats if it will work there).....you might have to get the regular cutout but you will lose a little clearance like i did with mine (maybe 2ish inches) putting it behind the cat or you can put it right on the DP in front of the cat and wont have that problem.
I have a DMH. $200 and its a 4 year warranty. QTP is only 90 days I believe. Ive also heard that QTP can get stuck and not function anymore. There were other threads about cut outs on here and many said to go with DMH over QTP
I have the DMH and the only problem I had was the motor coming loose one time. Just make sure to snug everything up good. I have had no other problems or complaints.
Just curious, but has anyone put the cutout after the resonator? Just wonder how that would effect the sound, and if it would have less of an interior drone and/or tin-ish sound. Thanks!
https://ls1tech.com/forums/ls4-front...aust-note.html
