LS7 lifters, trying to get facts straight
I am about to install some LS7 lifters and am wanting to verify what I have read. I also ordered a PR checker.
So, if the lifter cup is at its highest point, insert the checker to 0 lash, then take that reading + desired preload and viola, PR length acquired...?
I am also confused on a good preload, is this b/w .060 and .100? With the lower(.060) consisting of a noisier valve train compared to the higher(.100)?
Now when my LS7 lifters come, will they be bottomed out or at the highest point, or somewhere in between? How do I get them where I need them?
Do I need to soak my new lifters before install? Will this effect lifter preload?
I have read many a threads and have actually confused myself, haha
Cup should be at the highest point. Soak them in oil for a few hours before install. As for measuring PR length, get a checking spring as it wont compress the plunger. It would also help if you got adjustable rockers, but that's a whole different can of worms.
If you use a stock lifter with shims won't that give you the PR length for a stock lifter? He needs the the PR length for a LS7 lifter right? I only ask because I'm checking my PR length right now.
this is what I am looking for, a process where I only install lifters/heads once
Soak lifters
Install lifters and trays
Install heads/gaskets/bolts
Torque down
Insert PR checker
Install rocker, torque to 22 ft/lbs
Check PR length
Get proper PRs
Uninstall rockers
Remove PR checker
Install correct PRs
Reinstall Rockers @ 22ft/lbs
DONE, rest assured that everything valvetrain geometry is correct
Anyone have a procedure for this that doesn't install modifying lifters or torquing the heads more than once?
Soak lifters
Torque down
Insert PR checker
Check PR length
Get proper PRs
Uninstall rockers
Remove PR checker
Install correct PRs
