preload issue...
preload issue...
i am setting pinion bearing preload and i compress the crush sleeve a bit and when i spin the pinion it has a bit of a hang up and gets tight in one area and then frees up in another and it continues hanging up and then getting free..i am stumped to why it would hang up, all the bearings are new and seeded ok...anyone body have an insight on this delema??
i appreciate your time!!!
Did you oil the new bearings up good? You need them oiled up and set preload to 20-25 inch/pounds with a beam or dial type torque wrench. Then check how the pinion rotates. Also, did you install new races in the housing? They could possibly not be seated all the way.
preload
I have the opposite problem, I put in new races and bearings when I compress the crush sleeve I still have play in the pinion gear.
It rotates fine but doesn't seem like it's seated properly. How much effort did it take to compress the crush sleeve? It's a 10 bolt posi unit from a blazer.
I did put new races in the housing and i did oil the bearings up ( i didnt put a lot of oil on them but enough that they were lubed up decently) Ive gone through 2 crush sleeves so far, the first 2 crush sleeves i torqued them down to much but i had no hang up but just to much preload so i bought new ones from a local parts store and now i am getting the hang up...im thinking it has to be either something with the bearings being messed up or not seated correctly..
Some crush sleeves my impact will crush. Others it won't. If it won't, then I get the socket on a 24 inch breaker bar and have some else put a prybar in the yoke to hold it. Some of the crush sleeves can be a bitch to crush.
