boost limits
boost limits
i got my new engine up and running, 6.0 (403) Scatt crank/rods, Wiseco pistons, AFR 225 heads, EPP blower cam, D1SC w/8 rib belt-i run the corvette front acces. setup and blower designed for the vette-right now i am using the stock dia. crank pulley, and a 4.25 drive pulley, and a Procharger 3 core sheetmetal i/c, and a carb.
last year on the dyno with the old 6.0, i was seeing 9.6 lbs boost under the carb
i lose around a 1# thru the i/c, another 1-2#'s by the time it gets under the carb-i have a 4" drive pulley, was wondering if the 8 rib belt would handle the extra boost, fig 2-3#'s more maybe
i have a memory boost gauge, with the pressure release, so it only reads the highest boost, hard to see if i have belt slippage higher up
eventy. i will put it on the dyno, a little easier to read stuff than on the street, lol
would the 4" work ok, or could i actually reduce power if belt slippage
