umi help please
Old 10-16-2009, 12:27 PM
pozesd99''s Avatar
Default umi help please
im currently building a drag car....
i'm looking for a decent front spring for the track, but will see couple days a week on the street...
which springs do you suggest.... i would prefer a spring that is lower than stock but lets hear what you have to say
http://www.umiperformance.com/catalo...7utk8fpubi1sp6
Old 10-16-2009, 02:01 PM
UMI Sales's Avatar
Hello
Thanks for looking to UMI Performance for help! Lowering springs are great for corner cutting and road racing. BUT They aren't always the greatest for at the track (weight transfer wise) Don't get me wrong some suspension set ups can be descent but in the end it all depends on the spring rating. what we usually do is go with the heater hose mod in the rear with a good adjustable rear shock and a QA1 front coil over with a 300lbs front spring rate. And they still allow you to adjust the ride height as long as you get a spanner wrench (highly recommended). But if we do decide to run a lowering spring we go with the Strano springs. If you have any other questions feel free to ask and I will be more than glad to help. Below is a link to show you what all we have to offer.
Thanks
Brad
Old 10-16-2009, 02:47 PM
pozesd99''s Avatar
so a 300lb spring rate would work at the track well and will also drive "decent" on the street?
how much for the front two qa1 coilovers? with everything needed to install
Old 10-16-2009, 03:15 PM
UMI Sales's Avatar
Yeah they would be the perfect Street and Strip combo. If you have a chance give me a call and I can will be more than glad to work with you. And get your suspension to perform.
Thanks
Brad
Old 10-16-2009, 03:40 PM
taguy94's Avatar
Heater hose mod???
