master power turbo question
im looking at a used master power t-76 turbo. i have a stock ls1 with basic mods. looking to do a basic turbo kit. looking for around 5-550rwhp. is this turbo ok? will it spool too fast? it has a t3 housing. ill be reving to 6200 for the time being. also there are pics a few posts down, can you tell if its a t4 or a t3?
here are the specs
Master Power T-76 P-Trim Series
Rated up to 800 HP
Compressor Wheel Compressor Housing
Inducer dia. Exducer dia. Trim A/R Air Inlet
76.5mm 103.5mm 55 .72 101.5mm
Turbine Wheel Turbine Housing
Exducer dia. Inducer dia. Trim A/R Div/Undiv. Discharge Inlet Part Number
64.5mm 74.0mm 76 .96 Undivided V-Band T3 810047-396
here are the specs
Rated up to 800 HP
I think that might be a T4 .96 (The hot side should have it marked as far as A/R)
I have a MP T70 on my Stock (other than springs/pushrods/Injectors) 98 SS and even from a dead idle punch, it lags for a sec, but...when the turbo comes in....traction is gone...period.... so I would just plan on dealing with traction issues... I would'nt try to get a laggy turbo by any means!
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
Hey get ahold of Rob at ModularTubo, hes a sponsor here on LS1tech and his number is in my sig. hes really good with Master Power
yeah but i wouldnt take the chance. just like descreening the maf. no way. but yeah the 76 will be fine. you dont need a wider tire for stock purposes though? what type of tire is on the car? i would run m/t's and never look back. i think nittos suck the big one
