WTB front caliper bracket ASAP!!!
i need front caliper brackets for a 99 z28. the ones that are attached to the spindles. i only need the brackets and they need to have the sliders loose in them... (not seized)
1 Post
I don't know if you have yours and they are just seized, but if you can't get the pin out by using the penetrating oil, take the spindle off the car put it in a vise and heat it up with a torch and grab that pin with a pair of pliars and pull that sucker out. This is how I got mine out. Make sure to take some sand paper to the rust on the pin and on the inside of the slide. Blow it out real good and use plenty of grease when putting them back in.
