headgasket with 243's on a SBE
Old 10-16-2009, 10:51 PM
fordeater's Avatar
Default headgasket with 243's on a SBE
Will be throwing on a set of 243 heads onto my SBE ls1...what bore headgasket should I run? I would like to go with a GM mls gasket if possible, and was looking at these 12589226...will those work? any help would be great...thanks.
Old 10-17-2009, 10:25 AM
fordeater's Avatar
anyone?
Old 10-18-2009, 12:24 PM
fordeater's Avatar
No one has ran 243's on a SBE
Old 10-19-2009, 11:49 AM
fordeater's Avatar
bump??
Old 10-19-2009, 12:06 PM
mikep2002's Avatar
Whats an SBE? Sorry
Old 10-19-2009, 12:12 PM
NemeSS's Avatar
if its a 3.9, 5.7 bore, then any 5.7 gaskets will work, if its a 4.00+ bore then will need 6.0 or 6.2 gasket. its up to you what bore size and compressed thickness it needs.
Old 10-20-2009, 08:08 AM
fordeater's Avatar
thanks for the response...its a stock bottom end ls1...im pretty sure they are ls6 243 heads so I want to run a GM stock thickness MLS gasket...anyone think that would be ok?? and mike SBE means stock bottom end...
Old 10-20-2009, 12:52 PM
NemeSS's Avatar
the stock 5.7 mls gasket will work fine, SDPC usually has them in stock
