Drag Racing Tech
Need epoxy to bond aluminum to steel
Old 10-16-2009, 11:00 PM
InsaneAuto86's Avatar
Default Need epoxy to bond aluminum to steel
I cut out the tubs in my trunk and want to seal it off with flat aluminum sheet. What can I use to bond the aluminum sheet to the steel body?
Old 10-16-2009, 11:17 PM
MetallicaMatt's Avatar
black rtv, help keep the smoke out
Old 10-17-2009, 06:00 PM
I dont think rtv will be strong enough
Old 10-17-2009, 06:26 PM
why not just rivet them and then seal it with rtv or silicone
Old 10-17-2009, 07:52 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
TIG... I'm not sure about the metal compatability.
I'd use thin sheet of steel, weld it together, and paint it.
Old 10-17-2009, 09:01 PM
ATwelveSec02Z28's Avatar
Aint gonna weld aluminum to steel.
I would rivit and use JB Weld or RTV. If you want something permanent get 3M Marine 5200 sealant, Ive seen that stuff delaminate fiberglass before pealing off.
Quick Reply: Need epoxy to bond aluminum to steel
