start up problem
start up problem
Hi-just bought a 2000 B4C Code Camaro, right off the trailer the car had start up issues -battery didn't seem to hold a charge, then after several attempts with jumper cables it started & stayed charged, next day started right up -until I hit the rear hatch button -then wham no juice -completely dead. I just purchased a new battery, my question is if this doesn't remedy the problem I need some advice on what to replace next. THANKS TO ALL IN ADVANCE
are you getting 14v when the car is running? get a voltage reader and measure across the Negative and Positive side of the battery. This will tell you if the Alternator is not working. Good luck
