Compatibility of C5 clutch master to Camaro LS1 slave?
I'm attempting to mount a set of Corvette C5 clutch and brake pedals in my Avanti. I'm using a 2002 Firebird WS6 motor and transmission (T-56). It is my understanding that the C5 clutch master cylinder and and the F-body slave cylinder are both 3/4 inch bore, is that correct?
Are their any compatibility problems between these two items? Also, can I make or purchase a braided line that connects to both the Corvette clutch master and the F-body slave? I'm not sure if the C5 master cylinder has the same connectors as the F-body master cylinder. Can you specify a length?
Are all C5 clutch master cylinders the same? I see some offered for 1997-2004, and others 1997-2000?
Thanks for the help.
