Max cubic inch for MP122
Old 10-17-2009, 12:05 PM
s-cam's Avatar
Default Max cubic inch for MP122
What is the maximum displacement that an overdriven MP122 supercharger will support? Can it support 427, 434, 454 cubic inch engines or is it best to stick with a 402 and smaller engine? I have a 122 and 225 ET performance heads and I want to build the biggest motor possible.
Old 10-17-2009, 01:10 PM
raven154's Avatar
I would stick around the lower 400's with the 122. If you had a TVS2300 you might be able to push the bigger cubes but just to keep the 122 efficient, I'd stay in the 402 range.
Old 10-17-2009, 03:28 PM
Jontall's Avatar
This should help you... No guess work: http://www.eaton.com/EatonCom/Market...Maps/index.htm
Quick Reply: Max cubic inch for MP122
