Drag Racing Tech - Moser 12mm wheel studs?
Pro Stock John
12-05-2003, 03:45 PM
I see two 12mm part numbes for Moser press-in studs, one is 1.5?" and the other is 2.5", anyone used them yet? I need some for the front, I am assuming that 2.5" ones might work?
PSJ
not sure about the moser studs... I bought a set of ARP 2.5" press-in studs, and running 5/16" spacers up front with my prostars, they still weren't long enough to pass tech.
LS1x2
12-05-2003, 04:52 PM
With a 5/16" spacer up front and 15x3.5" pro stars these come flush with the holes in the wheels. They don't stick out past the lug.
Camaroholic
12-05-2003, 06:15 PM
I bought a set of the longer Moser studs to stick in my 12-bolt axles. It originally came with the shorter ones.
The shorter ones are low quality (IMO). They'll gall after a while of changing wheels. They're standard steel material.
The longer ones are *exactly* like the ARP studs (I bought a set of those too), except the longer Moser studs are black in color (unlike the ARP's which have a goldish appearance). Otherwise, they look the same in every dimension.
On my Bogarts, the longer / ARP studs are perfect on the back, but maybe .1" short up front (if you're talking NHRA-legal-to-the-digits). On the back, they do protrude in to the hex threaded portion (past the washer) by the diameter of the stud. On the front, they stick past the washer, but just an ooch short of a stud diameter.
-Andrew
Navy David SS
12-05-2003, 06:22 PM
PSJ
I got my ARP set from ThunderRacing. Perfect fit. My Moser Rear long studs have some rust from the few rains it has seen. The front ARP's are still perfect.
David
Pro Stock John
12-05-2003, 06:32 PM
Andrew I have black long studs in back you want to sell those Mosers?
Camaroholic
12-05-2003, 07:16 PM
I don't have 'em anymore, I had a local shop swap 'em while I was out of town. They trashed 'em, AFAIK.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
