Question on '98 stand alone harness
Old 10-18-2009, 06:27 PM
FoFittyFoSS's Avatar
Default Question on '98 stand alone harness
I'm wiring up my relays based on a schematic I found on here. There are three fan relays and two fans shown on the schematic. Fan #1 and #2 fast and slow fan. What is the best way to wire this for one fan and one speed using one relay? Has anyone done this? Sorry if this has been asked before.
Old 10-18-2009, 08:40 PM
ls1nova71's Avatar
If you only want to use one fan, then yes, use the fan 1 wire and wire it to one relay. My first swap has been wired that way for years. It runs the fan at full speed whenever it's on. It's the quickest and easiest way to do it.
Old 10-19-2009, 06:08 AM
Thank you.
Old 10-19-2009, 12:40 PM
ucf_stang's Avatar
where did you find the schematic?
Old 10-19-2009, 03:34 PM
Pocket's Avatar
lt1swap.com has enough schematics for you to get going
http://www.lt1swap.com/pictures/19_cooling_fans.gif
Old 10-19-2009, 08:56 PM
Email me and I will send you the pdf file I saved from here. Oasis_llc@yahoo.com
Quick Reply: Question on '98 stand alone harness
