View Poll Results: Boost cam
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Which cam do you like for turbo boosting?
I have the EPP FI Cam on a Rear Mounted T67.. other than that just 317 heads and a baby intake.. makes 550 rwhp and rwtq with no meth. Cam sounds sick too
Mind you its a stock bottom end, and EPP states the cam is good for like 1000 IIRC
I'm not asking so I can bite off someone else's set up I want to know to see what works for people with a turbo LSX. I am trying to find a cam that would fit my application yes but I am researching to see what kind of cam works for everyone (lobe separation duration etc etc) setup and rwhp.
Restricted User
You are leaving power at any power level with that cam. Boost is a power multiplier. Can you make 1000 rwhp with an LS6, yes, it's been done? But you can make it easier (less boost) with a bigger badder cam. But it will cost you a little more and more streetability the bigger you go. It's all a compromise. I went 6.32 @ 109.5 in the 1/8 with the stock longblock (stock heads and cam) at 16-17 psi. My turbo kit is identical but I forged the bottom end, lowered compression, slapped on a set of AFR225's and a Stage 2 Livernois cam 232/232 595/595 114. I believe that I will go faster than that on about 12 psi this Wednesday night.
LEP STS turbo Camaro SS Dyno. 634RWHP 661 Torque:
http://www.youtube.com/watch?v=DR4c6qz80GA
http://www.youtube.com/watch?v=5RN9CQnLWp0
http://www.youtube.com/watch?v=42O3U3KJXc0
http://leperformance.com/contact-us.aspx
