02 Power Leather Seats In a 1995 T/A?
I put 02 WS6 seats in my 00 SS and spliced into the factory wiring. T/A seats are different because they have the lumbar controls and crap as well. Under the carpet of a T/A there are air tubes that connect to both front seats and the pump is under the passenger seat (I believe). Without those, your lumbar controls won't work. Having said that, if you have manual seats now, most likely you won't have any plug under the carpet. Just run a positive wire under the seats and ground them. Splice into the 02 seats wiring and you should be able to go up/down/forward/backward. Hope that helps.
you should already have the air hoses installed in your 95 T/A. or was yours not a leather car? i know mine is leather and the hoses are there because the 95 seats have the same bolster/lumbar as the 02, they just don't have a power track. i am not sure if they installed those hoses in the non leather cars or not.
I just did this plug the harness from the old car into the power out let for the seat unsder the carpet and run the harness over to the passenger seatunder the console and plug them in the bottom of the seat
mine was non power in my 95 t/a but it had the lumbar. i just put my new seats in it was plug and play i have seats from an 02 t/a power i did not hook up the lumbar though because the system seemed a little different
I am putting 02 power leather seats in my 99 Pwr/Lthr seat Formula. My current driver's power seat has two wires. The 02 drivers seat has 6 wires. Are 4 not used? Also, my pass seat is not power but the 02 pass seat has the same 6 wire connector. Again, are only two used? Pass Power must be for the lumbar and air compressor. Just connect air hose from driver to pass, air pump is completely on pass seat?
