aluminum block power potential
Old 10-19-2009, 06:30 PM
THEBRAD's Avatar
Default aluminum block power potential
i have this in the gen 3 section also but it may be better here. r any of u turbo guys still using ls1 aluminum block on ur high hp turbo builds? i dont want the weight of an iron block and i dont want to spend 3500 on an lsx block after machine work. my goal is a daily driven 700hp with the potential to crank it to around 1100hp for some major decimation. i want to use something like a garrett gt55r so id assume boost pressure would be around 25lbs. any help would be greatly appreciated, i know a lot of u guys are putting down this kind of power, just want to see if its possible with a stock block
THEBRAD is offline
Old 10-19-2009, 06:33 PM
LS6427's Avatar
Oh boy...here we go again...... lol
For your goals....aluminum is perfectly fine.
And yes....aluminum if resleeved can handle twice what your 700 goal is.
And I don't think you need 25 lbs to make 700 RWHP. More like 12 lbs.
LS6427 is offline
Old 10-19-2009, 07:33 PM
02SSLE's Avatar
I am making 708rwh with a LS3 418 TTIX on 9 psi on low timming.
02SSLE is offline
Old 10-19-2009, 08:26 PM
Shawn @ VA Speed's Avatar
an ls2 aluminum block wil easily hold up to 1500hp with minor modifications.main cap walk and head gaskets are the 2 issues-i have fixes for both-let me know if you need any help
Shawn @ VA Speed is offline
Old 10-19-2009, 09:13 PM
THEBRAD's Avatar
700 was my dd goal with the option to hit around 1100 whp. was just making sure couldnt really find any write ups on it and everybody says u cant but i could see no reason it wouldnt. and thanks shawn ill pm u
THEBRAD is offline
Old 10-20-2009, 11:36 AM
Customizing Director
MadIceV8's Avatar
No need to have this posted in two forums!
MadIceV8 is offline
Quick Reply: aluminum block power potential
