Drag Racing Tech
battery in drop down box off frame rail?
Old 10-19-2009, 07:20 PM
InsaneAuto86's Avatar
Default battery in drop down box off frame rail?
edit* DONE... Thought you may all want to see. I still need to cut a piece of plastic to protect the battery from whatever the passenger tire kicks up.
Old 11-12-2009, 04:13 PM
pics added above...
Old 11-12-2009, 05:27 PM
outkast6991's Avatar
that looks like a nice setup. how hard was it to do?
Old 11-12-2009, 06:38 PM
Not to bad. Keep in mind that this is NHRA legal and now 35# of battery are keeping the passenger tire planted... I designed the battery support from aluminum and had a local guy weld it up. I also welded two 4" angle steel to the frame and bolted the battery support to the frame, so the setup is easily removable.
Old 11-14-2009, 07:36 AM
Ph.D. in HUBRIS
custm2500's Avatar
Looks good I need to do something like this on my truck.
Old 11-15-2009, 12:47 PM
sweetbmxrider's Avatar
not bad not bad. i like how you cut out that hole section and mounted to the frame rail.
Old 11-16-2009, 01:55 PM
Sandmann120's Avatar
Looks nice. Not a bad idea overall.
Old 11-16-2009, 02:07 PM
Ericbigmac83's Avatar
Why not just a box in the trunk? Looks like more work for no real gain that i can see
Old 11-16-2009, 02:38 PM
Skinny's Avatar
I'm sure there's a hold-down of some sort, but since I don't see it I'll go ahead and ask:
What's holding the battery in there?
Old 11-16-2009, 07:42 PM
Maybe more work but I wanted to do something different. Lower center of gravity and will hopefully plant the rear passenger tire a bit more.
There is an aluminum hold down. I should have taken a better pic with the rear bumper off.
Old 11-16-2009, 10:41 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
looks good, but might want to make sure you bring the tools, etc. when going through tech if they ask to see the hold down from the top.
Otherwise, nice job!
Derek
Quick Reply: battery in drop down box off frame rail?
