not quite sure?
not quite sure?
Im having a shifting issue and im not quite sure what it is? When im driving normal through town everything is fine. but when i decide to run through the gears it rakes in ever gear? idk but can someone please help me?
Internet Mechanic
How many miles on the car and is the clutch and hydralics orginal??
Going on some assumptions....
Change Transmission Fluid to something better. I personally use Pennzoil Synchromesh as my 2-3 shift used to scrub, now it does not.
Do a Fluid swap for the clutch master using DOT4 fluid, its not hard. Search for Gravity Bleed or Bleeding, there are many post on it.
If done right, this should eliminate 85% of your issue, if you have a dead clutch, then your going to need to do more and at that time replace the hydraulics.
BSM is sending you the right direction. There are several things to check and if you have any questions about specifics you are welcome to call me at any time. It is most likely a hydraulic issue but without more details on the car in questions it's hard to provide anything more solid than that!
