has anybody done this to there hood
i was wondering if anybody has put a mesh grille on there lt1 hood(circled on my car) just wondering if someon has done anything custom on there lt1 hood.
Have not seen this on TA's yet, but a bunch of us LT1 Camaro's have done it to ours. I took the plastic insert out, drilled small holes where all the dimples were, and cut out as much plastic behind the inserts as I could leaving only the mounting points for the inserts. The engine heat comes out when I stop and cold air goes in when I move. The only thing you need to worry about is rain since yours face up and backwards.
it wouldn't hurt the opti at all if you did it. the opti is like a foot back from those vents and if water went down them if would hit the upper radiator support and drain forward.
