AAAHHHHH! I'm yankin this tranny apart asap.. Help
Sup guys..
I think I've had it with this tranny/clutch.. I have a 6speed ss with some kind've high performance clutch(not quite sure what custom clutch the previous owner had installed in it). i've read the other threads but can't find one with same symptoms
symptoms-
-Comes out of third gear by Itself once in a while
-Clutch pedal has a lil more tension now
-the rpms over 4500 get whichever gear its in STUCK... Sometimes I can pump it a a lil to help force it out..
-When shifting it just grinds outta NOwhere and yanks back in neutral
-Hard to push it in reverse
I'm not too sure whats wrong with this but I Need to fix it. I'm just going to take it apart this weekend and hope i find the problem....
Any Advice is Greatly Appreciated guys... Help a fellow LS1 owner out ha
Thanks
symptoms-
Thanks
im not a complete expert but sounds like you need to rebuild that tranny man. the sticking in gear and popping out are clear signs something isnt right from my understanding. maybe someone with more experience will jump in here with a different diagnosis.
thx guys I've been researchin about my tranny/clutch and so far all of this info i'm gettin seems like its those synchros are bad and clutch needin adjustin just hope i can spot the problem when i take it apart When I end up fixin it I'll Post what the Problems were for Future References peace out
Alright guys. I took the t56 apart. Looked at the synchros and all of the gears. Everything looks good. No teeth missing. How can I tell if the synchro is bad? is it noticable? I just ordered a clutch and snap ring kit. When they come in. I'm goin to try to put this puzzle back together
Take a look at the picture below. It is NOT the actual gear the is going to be worn out but the engagement teeth. You can see in the pics that the little engagement teeth is worn down. The teeth should be sharp (when the sychro ring slides over the teeth and the clutch is not disengaged all the way, the grinding will occur). The second picture shows the synchro ring worn. The Tick Stage II is most likely what you will need, unless the engagement teeth are worn or missing.
in my case the situation with 3rd gear popping out was a worn syncro and when i would get on it the clutch peddle would not come back so a rebuilt 3rd syncro and new stock slave and master fixed the problem.
