Looking for a couple of write-ups
I tried using the search, but couldn't find what I needed, so I'm gonna ask directly.
Is there a write-up for doing the Formy/TA rear bumper swap, and one for the sanding/shining of the center brake light filler panel?
I know I'm gonna get flamed with "its called using search, douchebag!", but like I said, I already tried that.
Thanks for your time
Bumper swap, search "remove bumper." Theres nothing you reallyneed to change. You just remove one and put the other on.
tail light center section...320 grit, 600 grit, 800 grit, 1000 grit, 2000grit, plastic polish
