Fueling & Injection - What should my fuel pressure be on my car?
ohshixgoat
10-20-2009, 10:47 AM
I have 60lb motrons injectors, 2 inline walbro pumps. regulator. and a return going back to my tank.
any help will be appreciated.
wytry
10-20-2009, 10:49 AM
Well I assume its an adjustable regulator....so I'm kind of confused by your question. Stock pressure with the stock regulator is usually about 58 psi....
wytry
10-20-2009, 10:53 AM
Let me correct myself...LS1 pressure with the car off is appx 58 psi, I believe it drops around ten psi under load. If you're an LS2, pressure could be different...
ohshixgoat
10-20-2009, 12:09 PM
yes the regulator is adjustable. its a turbo car. stock fuel pressure is 57-58 so im going to adjust it down to that.
