12 O'clock & 12 O'clock...not DOT to DOT...cam install confirmation needed
I searched & replies were all over the place.
Please confirm that w/the #1 piston @ TDC on the COMPRESSION stroke, both the CAM DOT & the CRANK DOT are in the 12 O'clock postion. This is the correct orientation, cam to crank.
DOT to DOT ocurrs @ the bottom of the #1 piston stroke.
Thats exactly correct. The cam spins once for every 2 rotations of the crank, hence the reason why the cam gear is exactly twice as big. Every other rotation of the crank (when its on 12 o clock) the cam is at 12 o clock, and then the following rotation the cam comes back to 6 o clock as the crank comes back to 12 o clock.
