In need of a stock 2004 LQ4 tune for manual transmission
Title pretty much states it all.
I need a stock tune for a 2004 LQ4 with a manual transmission.
I was told the following vin fits that bill: 1GCHK29U24E103332
Bin file would work. I'm going to remove VATS and flash with Jet DST.
Misc info about my current PCM if it makes a difference:
PCM: 12586242
Calibration module info:
OS 12585950
Engine Cal: 12586060
Engine Diag: 12586214
Trans Cal: 12578773
Trans Diag: 12578790
Fuel system: 12578798
System Cal: 12585940
Speedometer: 12578995
I'm not looking for a custom tune at this point. In the near future, a custom tune may be coming.
PCM: 12586242
OS 12585950
Trans Cal: 12578773
Email the vin to John at tunercat he will give you the latest stock file for 25bucks or use a auto file and just tell the pcm its a manual it will shut off all the auto trans codes and functions. Its under constants in Tunercat so im sure its somewhere like that in Jet DST
I made up an ugly *** combo tune out of a 6.0 auto tune and a 4.8 manual tune. I had to change about 25-30 different items in 4 different secionts. It will run off idle now but it isn't ideal.
Here is what I got:
LQ4 from 2004 Silverado 2500hd 4 wheel drive truck
NV4500 manual transmission
VSS from 2004 Silverado feeding PCM
Axles have 4.88 gears
Tires are 35"
The engine is all stock except for Sanderson center dump headers and some generic aftermarket filter.
It is using the front set of o2 sensors. It has no catalytic. It is running a single muffler.
If you need any other information, please let me know what else I can provide.
Tires are 35"
And somehow I missed your early reply... yes, the two pcm connectors are blue/green. When I searched for a 2004 GTO, I found a LS1 version so I'm a little confused on using it. It would definitely be closer than my 4.8L hacked in job.
The situation just strikes me as funny beyond belief because when I was shopping for my LQ4, junkyards told me "never heard of one with a manual tranny". But everyone on the internet keeps say "I trip over LQ4s with manual trannies." yet when called to task, not a single person can provide a stock tune.
Yes, it is drive by wire.
