checking clearances when installing a new clutch
Is there a write up with step by step instructions on checking the clearances when installing a new transmission and clutch assembly. Concerned about the throwout bearing to pressure plate clearance.
Thanks
Thanks
https://ls1tech.com/forums/manual-tr...need-shim.html
This should provide you with what you need. Take a look and let me know if you have any further questions. Thanks,
