LS2/3 4 Bolt DBW with LQ4 Help
Old 10-20-2009, 11:25 PM
66DeuceLS1's Avatar
Default LS2/3 4 Bolt DBW with LQ4 Help
Does anyone know if I will run into any tuning/calibration issues if I combine an LS3 intake with the 4 bolt drive by wire throttle with an LQ4 short block which has a 24 tooth crank wheel rather than a 58 tooth unit? Is it a matter of getting the correct throttle control module to make this work or do I need to ensure that the TCM can interact with my ECM (which I have not decided on which model to get as of yet too)? Piecing together a motor for my 66 Deuce, but want to buy the right equipment the first time.
thanks
Old 10-21-2009, 10:11 PM
66DeuceLS1's Avatar
Any of the LS1tech vendors want to share their knowledge on this topic???? HELP is much appreciated!
